My 72 is nearing the end of repair/restoration of the HVAC and vacuum systems. I'm now making rapid progress since I've been laid off...
It's been almost 3 years since the car has run, and has been in my garage with the front wheels up on ramps for access.
After starting it up last week (no problems there!) I noticed that there was a little brake fluid leaking from the compression fitting at the far end of the steel line from the proportioning valve connecting to the flange leading to the Left Front wheel cylinder. I also thought that the brakes felt somewhat spongy compared to memory. I'm assuming that if fluid was leaking out, air was getting in, causing the spongy feeling. The master cylinder was still full.
At a minimum I know that I need to fix the leak (maybe as simple as tightening the fitting???), and then bleed the entire system.
The brake system has never been flushed in the 10 years I've had the car, and I don't have a clue as to when they were last done. I also can't say for sure what brake fluid is in the system (DOT 3, 4 or 5).
I've read a number of the posts regarding brakes, and based on the age of the fluid, assuming that I should really consider a complete drain/refill/flush of the brake system.
What else am I missing? Which fluid should I use?
Randy
Randy
Then leave set for a half hour or so. If all the fluid is milky color with little or no separation you have DOT 3,4 or 5.1. If there are two types of liquid with a clear separation you have DOT5. Refill with the same kind of fluid. For street use it doesn't matter if you buy DOT 3, 4, or 5.1 -- all will work just fine for you. Then fill the master with the right fluid and open the rear bleeder screws on one side. Watch the master cylinder fluid level and close the rear bleeder when the master fluid level gets half way or 3/4 of the way down. refill master and open the bleeder on the other side rear. You will have to get the nose of the car on the ground to do the fronts -- or get the rear up so the car is more or less level -- and repeat as above for the front. At the end you may need the help of some willing sole to pump the brake pedal for the final bleed.
