1966 M-20, Transmission - NCRS Discussion Boards
  • W K.
    • December 16, 2009
    • 61
    How do you know if you have the original transmission that came with your car?
    Re: 1966 M-20, Transmission
    Patrick------
    You look for the VIN derivative of your car's vehicle identification number stamped on the rear vertical surface of the main case. If it matches your car AND if it appears to be an original stamping, the transmission is original to the car. At least, the main case is original to the car. You have basically no way of knowing if any of the other parts are original to the car.
    • Ronald M.
      • August 31, 1999
      • 44
      Here is a picture of the VIN derivative stamping on my original M20.M20 VIN location.jpg
      Ron Myers
      '66 Roadster
      • W K.
        • December 16, 2009
        • 61
        Thanks for your help
        • David L.
          • July 31, 1980
          • 3310
          There should also be a stamped date code. My 1966 Corvette has a body build date of "F24" (February 24, 1966) on the body trim. The stamped date code on my Muncie 4-speed transmission is "P0211" (Feb. 11, 1966, and "P" = Muncie) along with the stamped partial VIN (last 8 digits of my VIN tag).
          Dave
