1957 Fan Shroud Installation - NCRS Discussion Boards
  • Ron B.
    • 58
    I never had a fan shroud on my '57. I recently acquired a four piece shroud from a '59. Seems like everything is the same(?). Everything is very tight and I was wondering what kind of clearances I need, other than the obvious. The bottom piece is right up against the radiator when screwed in place. Should that be, or is a little tweaking and bending in order? The passenger side frame piece rubs on the lower radiator hose. There doesn't seem to be enough room for the fan blade either. Did I read this shroud wrong? I can't conceive an actual '57 shroud being any bigger!
    I welcome your advice and if anyone can post pictures of a correctly fitted shroud, I would appreciate it. Thanks very much.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 1957 Fan Shroud Installation
    The fan shroud for a 56 & 57 is different from subsequent years shrouds which is probably why it will not fit properly.
