63 muffler ground straps question - NCRS Discussion Boards
    • 6940
    Were the rear muffler hanger copper sheets and braided ground straps used together or is just the copper sheets, I am a little confused by the JM it states in mid may the braided straps only. My car is a Mar. built
  • Joe R.
    • July 31, 1976
    • 4547
    Re: 63 muffler ground straps question
    Edward,
    Owned a 14,XXX bought from the original owner and it had only the brass sheets on both sides. NO braded copper ground straps.
    JR
      • 6940
      Joe, whats with JM it states copper sheets. brass sheets?
      • Joe R.
        • July 31, 1976
        • 4547
        Well then, the JM needs to be fixed!!!!!
        NOT copper but copper and Tin! That makes Brass!!!
        Very Brittle and will break easily. Broke too many!
        I think all the reproductions are correct.
        JR
        JR
        • Stuart F.
          • August 31, 1996
          • 4676
          I tried my best to use brackets with the brass sheets with my latest aluminized/welded exhaust system, but finally had to cut them off and applied the braded copper ground straps due to the vibration that the brass sheets transmitted to the frame. I believe that the repros are too stiff/heavy gauge and nulify the rubber portions ability to isolate the vibration.
          Anyone else have that problem?
          Stu Fox
