While working under the car today I found this little spring with one end broken off. What you see is about 3" long. It was hanging from the clutch linkage. What is it and where does it go? Can you buy them?
Where does this spring go?
Re: Where does this spring go?
Rev Mike,
That would be correct if we were talking C-2's. Think he has a 62 C-1. If he has a couple of springs he's got the wrong push rod. 62's had a threaded rod on one end and a lock nut with a spring on the other for the clutch fork.
Your probably correct that it is the spring for the push rod being that it was hanging on the push rod in the first place. There is a slot on the clutch fork for one end of the spring and a small notch on the push rod for the other.
JR- Top
This is a new 3760384 spring for a 58-63 transmission control. It looks different than John's spring.- Top
