Steering box Rebuild - NCRS Discussion Boards
  • Jack P.
    • March 19, 2009
    • 1135
    Good Afternoon Ladies and Gentlemen
    The last item of mechanical concern was my original steering box of 46 years of age. It performed wonderfully for years but it was time.
    I did not want to do it myself because of special set up procedures and if done correctly , would need no work in my driving lifetime.
    I called Gary Ramadei of Hartford CT....gary.ramadei@radiall.com
    203-776-2813
    He does profession work or both a standard build and a blueprint build. I would recommend him over the out of the box rebuild that you can buy if you wish to have your original box restored to better than factory.
    Several things can go wrong with the box. The gears themselves can wear out, adjusting the lash, crashes , time, lack of grease, rust.
    Gary is aware of my trip and wanted to make sure the box would be perfect....and it is.
    My car has all new front components, joints, rods, bushings , PS valve , springs, Idle arm etc. . The box was the last part to do.
    Here is a link to the complete set of photos , from Gary getting box to finished job.
    http://s633.photobucket.com/albums/u...fit87/Steering Box Rebuild/?start=all
    Here are some sample photos of the rebuild, You want a quality job done , Gary is one of the best in the business.
    Old Box
    [IMG]http://i633.photobucket.com/albums/uu57/jackfit87
    /Steering Box Rebuild/asrecd1.jpg[/IMG]
    Lash all the way in (bad)
    Rebuild
    New Gears Seals Bushings
    Fitting and adjustments
    New lash
    Marking for center of travel index
    Finished Box
    I will do a follow up post on the alignment done today so that box all components are set up perfectly for my kind of ride.
    I used Palmer Spring Company and will have photos of their shop.
    They still make the springs right in their shop as well as all that is involved with suspension parts. Been in business since 1849.
    I will have photos of the blacksmith shop still in use for springs and metal fabrication.
    All my suspension components are stock and like new and the car rides perfectly for a 1966 corvette , just like new ( the old new) .
  • Jack P.
    • March 19, 2009
    • 1135
    Car goes straight
    The weather was OK today and I wanted to test the steering box rebuild along with the alignment to match all the index marks . I will update this post with pictures of the shop that performed the work. (Palmers Springs Shop) Here is a video of the car accelerating from 10 mph to 70 ish without any hands on the wheel. I wanted to see if the car would steer straight. A picture is worth a thousands words. Great rebuild from Gary Ramadei . Car is now safe , stock and very reliable for my long trips. Just click
    • Paul Y.
      • September 30, 1982
      • 570
      Re: Car goes straight
      Wow Jack, nice upgrade. Looks like you won't have to steer that thing in Europe.
      It's a good life!
      • Jim S.
        • August 31, 2001
        • 730
        Gary is THE MAN when it comes to rebuilding C2/C3 Corvette recirculating ball gears.
        Jim
