Are 454 LS-5 pistons still available from GM any more? What if any parts are still available for LS-5 engines any more from GM
NOS GM 454 pistons LS-5
Re: NOS GM 454 pistons LS-5
Lyndon-----
LS-5 pistons have been discontinued by GM for over 30 years.
So, what's still available? Very little. Things like head bolts, engine bearings, flywheel, timing set parts, and a few other odds-and-ends are about it.In Appreciation of John Hinckley- Top
Lyndon-----
The GM timing set uses a nylon/aluminum cam sprocket and Morse-type chain. I use and recommend only Cloyes True Roller sets. The flywheel is GM #3993827. A balancer is also still available but not under the original part number. However, this balancer is very similar to the original except that it is powder-coated black. It is GM #10216339.In Appreciation of John Hinckley- Top
