1972 fuses - NCRS Discussion Boards
1972 fuses
  • Jerome P.
    • October 22, 2006
    • 607
    1972 fuses
    Does anyone know the color coding for the fuses in the fuses box or were I could find this info?
    Also, does anyone still sell the color coded fuses?
    • 6940
    Re: 1972 fuses
    Jerome, The fuse colors for your 72 , Red= 10AMP, White= 25AMP. The small dash lite fuse is brown=3AMP?, Clear= 20amp. hope thats right I am doing this from memory.
    I think that member Pete Lindali sells color coded fuses.
    • Jerome P.
      • October 22, 2006
      • 607
      Re: 1972 fuses
      Thanks Ed. I have/will contact Pete
        • 15573
        Re: 1972 fuses
        I am pretty sure that super secret color code (I think the 3 amp = purple, but check to be sure because I too am working from memory) is in the 1970-72 TIM&JG, but don't tell any one or the secret will be out.
        • William C.
          • May 31, 1975
          • 6037
          Re: 1972 fuses
          For those who "just have to know" see attached.
          Bill Clupper #618
          • Jerome P.
            • October 22, 2006
            • 607
            Re: 1972 fuses
            Your chart is great.
            The TIM&JG could maybe be use some of this info to enhance the info already found therein.
            • Mark D.
              • June 30, 1988
              • 2142
              Re: 1972 fuses
              (I think the 3 amp = purple)
              You're such a clod, it's violet, not purple.
              Kramden
                • 15573
                Re: 1972 fuses
                I can get Zoe to introduce you to some people who care about that difference, if you want to change your luck.
                  • 15573
                  Re: 1972 fuses
                  The problem with putting too much information in the manual is worse than having not enough information. If we put that list in I could forward to you all the questions from people who would want ALL those pretty colors in their fuse panel. Trust me, I have been there; and recently too.
                  • Jerome P.
                    • October 22, 2006
                    • 607
                    Re: 1972 fuses
                    I understand, but the operative words are "some of the info" i.e. color = ampere. Not just a couple, but all applicable fuses with associated color and amperage.
                    The manual is well done and team that put it together did a great job.
                    • William C.
                      • May 31, 1975
                      • 6037
                      Re: 1972 fuses
                      Keep in mind that there were two suppliers of fuses each with their own interpretation of the specified colors, as well as different methods of color application.
                      Bill Clupper #618
                      • Jerome P.
                        • October 22, 2006
                        • 607
                        Re: 1972 fuses
                        Bill, Do you have the suppliers names, websites, etc?
                        • Paul O.
                          • August 31, 1990
                          • 1716
                          Re: 1972 fuses
                          Mark In a Electronic Cockpit it is called Magenta you got to get out of that B737-200 things have changed.
                          Paul 18046
                          • William C.
                            • May 31, 1975
                            • 6037
                            Re: 1972 fuses
                            Buss and littlefuse were our only sources. I do know each had a different process for applying the colors, resulting a slightly different appearance, but both were used interchangibly
                            Bill Clupper #618
                            • Dave S.
                              • August 31, 1992
                              • 2918
                              Re: 1972 fuses
                              I hate to spoil things for the color sensitive folks who posted earlier. My 71 does not have a 3 AMP fuse. It has a 5 AMP for the instrument lights. Is there a special color for 5 AMP fuses.????
