'72 condenser removal - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    Any help? I tried to wiggle it out but the outlet tube on the bottom right is holding me back.
  • Bill C.
    • July 15, 2007
    • 904
    Re: '72 condenser removal
    When I started the restoration I had to take the condenser and drier out as an assembly.
    It was easier to undo the tube fittings. My assembly was original and did not want to break down in the car.
    • Tom L.
      • October 17, 2006
      • 1439
      The condenser is completely disconnected. Still can't get it past the hood.
      • Bill C.
        • July 15, 2007
        • 904
        hood has to off the car - no way to get it out otherwise.
        it also will help if you loosen up the core support bolts on the side, if you push it back a little towards the engine it will help getting past the headlight vacuum actuators.
        • Tom L.
          • October 17, 2006
          • 1439
          Hmmmm... Seems the obvious was what it is. I was hoping for a simpler solution. As always, thanks for the insight!
          • Bill C.
            • July 15, 2007
            • 904
            there aint a damn simple thing on the entire car.........
              • 15573
              Amen Brother.
              • Kevin G.
                • February 1, 2005
                • 1074
                Depends on who's behind the wheel....
                • Tom L.
                  • October 17, 2006
                  • 1439
                  I've only had the car for about five years. As I go through different parts of the car I'm figuring it out. There are days that I've thought that who ever put big blocks in these thins was a real joker.
