Re: Front spring replacement?
The Chevrolet Service Manuals (at least the early C3 versions) show removal of the Corvette lower control arm by removing the inner lower control arm mounts and lowering the control arm. I never tried it that way, but I suppose it could be done. It is probably a little safer in that if the spring pops out it will not go far or do quite so much damage.
Separate the ball studs with:
or make your own. I think there is an old thread in the archives showing how to make one like this.
or if you intend to replace the ball studs anyway the old "pickle fork" will do the deed with the accompanying damage to the rubber seal.
I have done the front springs/spindle/ball joints on the ground with jack stands, and on a lift with Snap-on spring compressor and clips to hold the spring in the compressed curved position. The latter is a lot safer, but no less work other than getting up and down off the floor. Either way the job requires a little (well maybe more than a little) common sense and thought and a whole lot of hard work. Undercar suspension work is almost always dirty greasy hard work -- just a fact of life. Be careful.
