what size were the original castle nuts for the tie rods, 5/8 or11/16 nut size?
Tie rod castle nuts ?
Re: Tie rod castle nuts ?
Craig,
I think the slotted hex nuts are 5/8" across-the-flats, but I'm interested to know if others confirm.
I also read Joe Lucia's comments in the archives that the bottom of the "slots" on midyear Corvette slotted nuts should be rounded, but I recently noticed both "rounded" and "straight" slots in pictures I took of the '67 survivor used for the morning Judging seminar at McDorman's a couple years ago. I don't recall if Joe's post was recent or not, so I don't know if the 'rounded' vs. 'straight-cut' slot info is up to date.- Top
Craig,
Two slotted hex nuts that were on my '67 tie rod ends are 7/16-20 thread, 5/8" across the flats, with the 'rounded' slot. I have one example from a 1969 P/S relay rod asm. that is also 7/16-20 thread and 5/8" across the flats, but with the 'straight-cut' slot. Unfortunately, I don't know for sure if either one is production line original.- Top
Craig------
The nuts were SLOTTED nuts and not castle nuts. Castle nuts have a different configuration. Original nuts used for 1963-82, GM #102646, were 5/8" across-the-flats and 3/8" thick. They were PLAIN finish and SAE grade 5 material.In Appreciation of John Hinckley- Top
Joe or anyone, do you have pictures of the 2 nuts to show config difference? thanks.Michael
70 Mulsanne Blue LT-1
03 Electron Blue Z06- Top
Michael-------
Yup. The nut shown on the left is a SLOTTED NUT. The nut shown on the right is a CASTLE NUT.
slottednut.pngcastlenut.pngIn Appreciation of John Hinckley- Top
- Top
