Possible To Install Positive Battery Cable in C-3? - NCRS Discussion Boards
  • Rich C.
    • January 1, 1994
    • 383
    Short of removing transmission (it's a 73 Automatic), can the positive battery cable be properly replaced? Looks like a several pint job!
    '73 Ls-4 454, owned 21 3/4 years
    Otter Creek - Copper Ale, currently on tap!
  • Don L.
    • August 31, 2005
    • 1005
    Re: Possible To Install Positive Battery Cable in C-3?
    I think the auto trans is larger than the 4 speed, so if it's possible to do I'd imagine it to be even more of a challenge than the 4 speed.
    I was successful in getting my cable replaced with the 4 speed trans in place. Not an easy job!
    My unsolicited advice would be to make sure you have a 7/16" swivel socket in 1/4" drive and a nice long extension too. You need to remove all the cable-to-body clamps and there are a few above the trans (under the foil insulation mat).
    Hope this helps!
    Don Lowe
    NCRS #44382
    Carolinas Chapter
