I think I am screwed - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    Re: I think I am screwed
    You can check your vin tag No. to the frame if you are curious, on the driver's side toward front of seat on top of frame is the no., mine was under the rubber spacer, used a piece of tape, don't remember what kind, I think you can get some for this purpose, find exact spot put tape over it mash down good and pull it out and it should have the vin from frame on it. Good Luck, Brad
