68 roadster springs cut (photos) - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    About a month ago I talked about cutting one coil off of the tightley wound end of the front springs on this 68 to lower the high front end, this is how it came out, summer photo is before and winter photo is after cut front coils.
    JR
  • Dan M.
    • March 6, 2009
    • 157
    Re: 68 roadster springs cut (photos)
    I agree it looks much better but why was it high tio begin with? Aftermarket springs? I couldn't find your prior posts.
    • Jim R.
      • June 30, 2001
      • 643
      Hi Dan we never did come up with reason for it sitting high in the front, my friend has only owned the car for a year now so anything is possible, although the springs did look original and had tags on them but could not read the numbers.
      JR
      • Terry B.
        • August 31, 1999
        • 607
        Hi Jim,
        The pictures look like you corrected the problem. I wonder if there is a down side to cutting the spring? How much did you remove? Is your friend's car a big block or small block?
        Terry Buchanan
        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
        Corvettes Owned:
        1977 Coupe
        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
        2003 Electron Blue Coupe
        2019 Torch Red Grand Sport Coupe
        • Jim R.
          • June 30, 2001
          • 643
          Terry we cut one full coil from the tightley wound end of the spring this is the soft end. the car is a smallblock with air 4spd.
          JR
