c3 brake booster test - NCRS Discussion Boards
  • Randall K.
    • April 1, 2005
    • 184
    From this post (https://www.forums.ncrs.org/showthre...replacement-c3), it seems that an alternate test method would be to use a vacuum pump instead of intake manifold vacuum to test the booster. I assume that the master cylinder does not need to be in place for this.
    True??
    Randy
  • Russ S.
    • April 30, 1982
    • 2161
    Re: c3 brake booster test
    Randall, You are correct on both counts.
