This is for a 70 Coupe L46.
Can someone explain why there are two types of heat shields for cylinders #1 & #3? One page of the AIM shows a triangle shaped heat shield (item #18) and another page shows a straight type heat shield (which is common for the other cylinders).
If you install the triangle heat shield the outer chrome heat shield cover will not go over it. Any ideas?
TIA,
Mike
TIA,
Mike
