does it interchange with any other GM car. the one I have the one ball and socket joint is loose. also with the dipstick be the same on any other GM cars. thanks
67 427 power glide kick down linkage
Re: 67 427 power glide kick down linkage
From my experience when I was looking for my pcs, I don't think they do interchange although there are parts of them that do such as the belcrank. I don't think the linkages do. LI corvette does have what you need.- Top
Keith------
The upper rods are unique to Corvette (and also different for L-36 versus L-68).
The bracket assembly (with "bellcrank") is common to all 67-68 passenger, Chevelle, Camaro, and Chevy II with Powerglide.
The lower rod is common to 65-68 passenger car with big block and Powerglide and also common to 65-68 Chevelle with big block and Powerglide.
The dip stick is common to 1965-66 passenger cars with big block.
There is no utilization of any of the above parts for other GM cars.In Appreciation of John Hinckley- Top
