54 oil pan leak - NCRS Discussion Boards
54 oil pan leak
  • Guy M.
    • November 1, 1993
    • 499
    54 oil pan leak
    I fired up the chasis this morning and I have a oil leak at the front of the pan. Question........ does the two bolts that bolt to the timing cover from the inside need to be sealed? The pan and timing cover seal dont show signs of leakage. I didnt seal thse bolts. I appreciate the help.
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 oil pan leak
    are you sure where it is coming from....
    the leak from a couple places.....
    at the corners of the pan....
    at the front timing cover
    and from the oil hole - to the left of the water pump - should have a freeze type plug pressed into it
    I have take a syringe full of RTV and sealed the corners at the pan.
    the needle can get into small places
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
