Correct C1 A arm bushings - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    Are there any current sources for the correct A arm bushings with the GM stamps and recessed heads or do I need to go to the junk yard. A previous post by Mike McCagh said that the 49 to 54 passenger cars had interchangeable A arms, shafts and bushings.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • John F.
    • March 23, 2008
    • 2395
    Re: Correct C1 A arm bushings
    I got the whole kit from Paragon an am very pleased. I don't think you can should try to find used bushings. Hopefully Tom Parsons will add some comments. You need to seacrh and read his step by step of rebuilding the front end of a C1.
    • Adam S.
      • July 30, 2008
      • 167
      1957 NOS Suspention lower control arm shafts 3693459 200 2.jpg1957 NOS Suspention lower control arm shafts 3693459 200.jpgHi Keith , you still can find NOS lower & outer A arm bushings on fleebay & other sights, as long as they are in the yellow & black 1st issue boxes they usually have the correct style nut. The eariler 1940's NOS lower shafts are incorrect as they have jam nuts on them..........The ones in pictures may still be too early, but will work on early C1's.
