I am replacing my Radiator (Dewitts of course) and front Radiator support on my 66 vert.
Once I pulled those two items, I noticed that the Grill had been Baba'd into place. missing screws, Center top and bottom mounts not attached, other points, machine screws and nuts were used, the two front support rods weren't even bolted in place and were just hanging. I am glad no one put any force on the nose of my car.
In the photo below, is a riveted metal (to fiberglass lower valence)front center plate, which you screw the center bottom Grill mount into. This does not look right to me. For one, the Rivets holding the plate in place are newer and the plate looks to big.(almost home made)
Can someone please forward a photo of this area?
Also, from what you see, is anything else not correct.
I can see project creep coming on!!!!!!
I called LIC to ask the question if they carried a replacement correct center plate and he had no clue. in section 03, of the LIC cataloge, can anyone see where that plate would be located, so I can order it along with a long list of other items?
Thanks in advance.
Thanks in advance.
