Re: Correct Primer Over Lacquer
Just my opinion, but have you considered reshooting acrylic lacquer over the original paint? Then there won't be any incompatabilities with paint types or finish, and it preserves the OEM value. BC/CC is a great modern system and is highly durable, but it looks different than a single system such as acrylic lacquer (AL). And yes, AL is not as durable as BC/CC, but if your car is a Sunday driver than AL is just fine.
If you are going to paint AL, then a traditional high-build lacquer-based primer is best because the solvents will bite into the original paint. Then top coat with AL after wet sanding the primer (I am presuming the original paint is sound and not full of spider cracks). The beauty of lacquer is that it is forgiving (mistakes such as runs can be corrected easily) and it can be touched up at any time, but the trade off is that it has to be wet sanded and buffed after spraying to get the shine up. But it shines like nothing else if done right!
If you decide to go with BC/CC, then as the others suggest, it is best to strip the car. But if you use a solvent stripper, be sure to let all of the solvents evaporate before painting or air bubbles will permeate the paint later on. Murphy's law directs that they will appear in the most visible places just to aggravate you even more.
This link provides information about the various primer options. Navigate around the site to learn anything you need to know about painting including the different types of paint and relative prices for each. They can mix custom Corvette colors in any paint system based on paint chips in their library.
Whatever system you choose, I can't emphasize enough the importance of degreasing and dewaxing before painting or stripping. Wash the car throughly first. Then wash it again and scuff the entire surface with Scotchbrite pads and dilute citrus cleaner. Then wipe the entire car down with water-based wax remover. Be sure to use a tack cloth before spraying.
Lastly, here is a tip on how to confirm the type of paint presently on your car: Get some lacquer thinner at Home Depot, saturate a cloth with it and wipe it on an inconspicuous area. If after some rubbing nothing comes off then it's BC/CC. If some color comes off then it's lacquer. If it curdles, then it's enamel based. You could also sand a smalll spot. If it comes up with white dust then it's BC/CC, but if color comes up it's either lacquer or enamel.
Good luck!
Good luck!
