Remove rust from frame - NCRS Discussion Boards
  • John C.
    • March 15, 2012
    • 9
    Re: Remove rust from frame
    I actually changed my mind on the dipping due to several stories of people having them dipped and then later having them rot out because they were not well cleaned following the dipping process. I had it sandblasted by Multi Media in Pulaksi, PA. They did a pretty good job. I think they were a bit aggresive and could have done a little better in a few corners, but overall, I would do it again.
    • Robert K.
      • July 31, 1984
      • 213
      I would paint the inside of the frame using an undercoating wand and your choice of paint. I've used POR 15 on Jeep frames and problem solved. I suspect people with rot out after chemical dipping was because they didn't coat the inside of the frame.
      • Dick W.
        • 10483
        The rot after dipping started long before they were dipped, I guarontee that The dipping did nothing to inhibit or promote the rot. Ya start with peanut butter, and sooner or later ya ends up with peanut butter. You start with gold and it stays gold.
        Dick Whittington
