I'm having trouble removing the ignition nut from the ignition switch. It loosens up, but won't come all the way off. I'm thinking it may be stripped, but want to make sure there's not a "trick" to take it off. Please let me know.
67 ignition nut
Re: 67 ignition nut
Joe,
The nut will not come off without removing the tumbler first. Do you have the key? Put key in and turn towards accessory and push your pin in while lightly twisting it and it will pop out. Without the key, well you need a locksmith that knows the old B&S locks.
Or if you can remove door panel and remove a door lock (assuming all are original) and read the code number stamped on the lock you can have a key made for the ignition with that as it was same originally
Bill- Top
Re: 67 ignition nut
Joe,
If you look with a strong flashlight as you turn the key, you should be able to see the pin as it lines up with the hole in the lock. Once you see it, insert the small paper clip and press the pin in. Once you do that continue to turn the key and the cylinder should turn and then come out.
Good luck.
Dennis- Top
