I'm in the process of putting my original master cylinder back in and am at the point where I will need to bench bleed the unit. I've read the procedures about doing this that I located in the archives but I did not see mention of one detail. Can the master cylinder be bench bled with the proportioning valve already installed onto it? I'd like to remove the air from both the master cylinder and the valve so I have a minimum amount of air being put into the lines that will need to be bled out. Is this OK to do or would it adversely affect the valve? Thanks.
Joe 45420
Joe 45420
