Wide band O2 analyzer - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1354
    Anybody use/know of reasonably price wide band exhaust analyzer(Auto Meter brand?) temporarily plugged int 'bungs" welded into exhaust pipes near manifold to check air/fuel mixture and help with carb jetting?
    '67 L36/C60/J56 coupe
    '67 L79/C60 coupe
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Wide band O2 analyzer
    you will a long stretch of road to hold it wide open to get a good reading. you could find a dyno shop with a chassis dyno to do the job.
    • Joe C.
      • August 31, 1999
      • 4598
      '67 L79/C60 coupe
      This one keeps the cost down by eliminating the display. If you own a laptop, you install the software and set the laptop on the passenger seat while testing. I like it because you use the big laptop screen for readouts:
      Wideband AFR Lambda Datalogging, Gauges, wideband o2 sensor kit for carb tuning, Sensors, Pressure, MAP, Thermocouple, Temperature
      A screenshot of the ZT2 readout:
