I've been playing around with a rebuilt 3461S on my L-76 63 that I got from one of our great members. From day one it has had a lean surge at high vacuum cruising in 2nd and 3rd. Even after every measure I have taken to correct this, I now instead have a "herky jerky" under those conditions. I also have a 3721SB which, when installed, does not exhibit these faults. Therefore, I've ruled out any other source including ignition.
The carb first had primary clusters with .033" low speed/idle jet tubes (incorrect), so I enlarged them to the stated original size of .035" (no change). I then changed to earlier model clusters with .037" jet tubes (no change). The primary jets were .098" (not correct), so I changed them to .104" (std.) (still no change). My good friend Tim B. suggested I might have too much timing and still too lean. I'm running a corrected 12 degrees initial with a B28 VAC. I then changed to richer metering rods: .065" x .057" (from .069" x .060" std.) (still no change).
I took the car out again for test drive yesterday. It ran well for the first 10 to 15 minutes, i.e. started well with good warm up, very responsive off idle, and super POT and WOT. Then again it started the "herky jerky" at high vacuum in every gear. I considered turning around and heading for home thinking I may be losing a coil (and me w/o my cell phone), but it settled down and was less noticeable on my return trip.
What I can't figure is why this is occurring with the 3461S and not when I'm running the 3721SB. I'm ready to just put the 3461S on the shelf as a correct carb for the car - a trophy!
Stu Fox
Stu Fox
