i was curious to valve adjustment for drivabilty on my 64 fuel injected car with the duntov cam. the car has 4:11 gears and cruises about 3500 at 65mph. it seems real happy there. the current valve adjustment is 12/18 with full roller rockers just put on this week. i had roller tip rockers in the past when all the problems occured. we are thinking the full roller rockers will relieve most of the strain that my valvetrain seems to be having.
i have been researching the archives trying to find a cure to my problem. i like to drive my car as much as i can. over the past couple years i have had problems with the adjustment backing out all together which was cured with poly locks and recently on cylinder #1 the intake screw in stud just snapped. my engine builder is a great mechanic and he has been building these engines for over 30 years. he has never seen this. we are both trying to figure this out. i have no reason to question him. i am just trying to figure this out and keep it from happening.
my engine was decked as was the heads to true them up.but i dont recall how many thousandths. the engine is 60 over. the heads had new seats cut into them and spring pockets recut? the spring pressure was within specs. i was there when he was checking that. the heads needed alot of work to save them.
could the consistent rpms not be favorable at highway speeds? i thought the 327s loved to rev and this one does.
with the heads and block being decked could the pushrods be too long now? wouldn't the adjustment on the solid cam take care of that if that was the case?
i appologize for all the questions but after having the same problem a few times, it is getting confusing for me and i would love to put my mind at ease when i'm driving.
i appreciate any advice.
take care,
matt
take care,
matt
