carb metering block removal - NCRS Discussion Boards
  • Craig F.
    • March 1, 1986
    • 55
    What is the best way to loosen metering blocks from the main body of the carb? What should I use to soak it in that will not remove the finish to the main body or the metering blocks?
  • William C.
    • May 31, 1975
    • 6037
    Re: carb metering block removal
    might help if you were to clarify just which version of the metering block you are referring to. If it is a Holley with the metering block that is held on by the float bowl, a sharp rap on the side of the block with a soft faced hammer should do the trick If it is a secondary block held on with the funny-looking screws, remove the screws and peel the gasket, the block should come with the gasket that is under it.
    Bill Clupper #618
    • Craig F.
      • March 1, 1986
      • 55
      Sorry, it is a 2818 holley so the prim and sec blocks are held on by the float bowls. I have tried a light tap with a rubber hammer after soaking with WD40 and tried a small flat blade screw driver around the side but neither of them want to budge. The carb has been sitting in a dry storage shelf for 30 years and all the other parts came of fairly easy.
      • Clem Z.
        • January 1, 2006
        • 9427
        try this http://www.permatex.com/products/Aut...et_Remover.htm
        • Craig F.
          • March 1, 1986
          • 55
          Thank you, this should do the trick!
          • Craig F.
            • March 1, 1986
            • 55
            Thanks for the tip on this cleaner. One can of this and several hours of work later and all the parts look like new, ready to rebuild.
