Installing extra fuse protection
Tags: None- Top
Re: Installing extra fuse protection
Nick..I think 67 was the first year for the lighter fuse. A 20 amp fuse is used and the clock, lighter, courtesy and hazard warning are on the circuit..Bill- Top
Nick -
The main power feed circuit for the whole car from the big battery cable stud on the starter solenoid also didn't have any protection until 1967; you can add a 16-ga. fusible link on the end of that 12-ga. red wire (photo below shows a 14-ga., but you need a 16-ga.).
FusibleLink.JPG- Top
We, I think, are trying to prevent the dash area from a fire! The biggest problem has been the cigarette lighter. Since GM in 67 spec a 20Amp fuse for it and a few other items then that would be the largest size to use. Could use something smaller, but just what size would need to be calculated. That step is really not necessary since if the 20Amp blows the wring to the lighter should be protected (at least that's what GM felt and they seem to know). I would use a standard in-line-fuse- Top
- Top
