molded vacuum actuator hoses - NCRS Discussion Boards
  • Robert M.
    • January 1, 1992
    • 78
    I purchased a new headlight vacuum hose set and 2 of the hoses (green and red) have a 90 degree molded end on them, do the molded ends attach to the vacuum canister or to the vacuum relay switch?
    Thanks Bob Moon
    • 15573
    Re: molded vacuum actuator hoses
    The one that goes on the front of the actuator (I hope your kit came with instructions because I can't remember the stripe color) is molded 90* on many 1969s. I suspect the one going to the rear of the actuator is as well. Are there no instructions with your hoses?
    • Paul O.
      • August 31, 1990
      • 1716
      Bob
      As with what Terry said it would go to the headlight actuators green on the front toward the bumper and red on the back toward the radiator.
      Paul 18046
      • Robert M.
        • January 1, 1992
        • 78
        Thanks guys, It did come with instrctions but they were incorrect as to where the molded hoses go. I assume they were used on a 68
        • Michael D.
          • June 30, 1996
          • 536
          The assembly instruction manual (AIM) shows the hoses, correct colors, routing, etc.
          • Rich C.
            • January 1, 1994
            • 383
            Your not going to tell us where the hoses came from, are you?
            '73 LS-4 454, owned 21 3/4 years
            Smu ttynose 'Finestkind' IPA, now on tap!
            • Robert M.
              • January 1, 1992
              • 78
              purchased from Paragon, aside from the error in the instruction the hoses fot great
              • Graeme B.
                • October 23, 2007
                • 213
                The red and green hoses were swapped around sometime in '69.
                I think there is even a note in the AIM.
                Cheers, Graeme.
