Oil pan plug - NCRS Discussion Boards
Oil pan plug
  • Michael G.
    • November 12, 2008
    • 2155
    Oil pan plug
    Can someone please post a pic of the head marking of a correct 63 L84 oil pan plug?
    Re: Oil pan plug
    Mike -
    The JG indicates that only the "M" drain plug is correct; actually, there were multiple vendors, and the "L", "A", and "TR" drain plugs were also used. The two engine plants used about 12,000 of these things every day, and they didn't all come from one vendor. Photo below (from Jack Humphrey, I think) shows the other three drain plugs.
    • Michael G.
      • November 12, 2008
      • 2155
      Re: Oil pan plug
      Thanks John, Someone in the last 49 years buggered up the the threads in my pan, so I've chased the threads with a tap. To avoid screwing (pun?) them up again, I am making a new MAThread version of the plug from scratch. The current plug does not have any head mark, so I know its wrong. My head marking options are open, so I'll just pick one of the four you noted and burn it on the new head...
      • Peter H.
        • April 1, 1980
        • 223
        Re: Oil pan plug
        MIKE YOU SHOULD DO A RUN FOR ALL THE MICHIGAN CHAPTER MEMBERS... PETER ..
        • Michael G.
          • November 12, 2008
          • 2155
          Re: Oil pan plug
          Peter, While I'm at it, it'd be easy to make one to give to all the guys in the Chapter , but, we have to keep it a secret ....
