Shifter Mounting Bolts - NCRS Discussion Boards
  • Barry N.
    • July 29, 2007
    • 14
    What would be the correct finish on the mounting bolts of a 1966 Corvette Shifter?
    Re: Shifter Mounting Bolts
    Barry-----
    There were actually two different shifter mounting set-ups for 1966. Early used a shifter mounted to a bracket attached to the transmission extension housing. Later used a bracket mounted to the crossmember. In either case, there were two bolts that attached the shifter to the bracket. The long bolt was black phosphate-finished. The short bolt varied depending upon which shifter mounting was used. However, I believe that either of the bolts were black phosphate-finished.
