Surveying the 7 or so ignition distributors I have (C2-C3 era) I notice the slot cut into the bottom of the machined "boss" at the bottom of the oil annulus [see housing on right in the picture]. Is this for oiling of the camshaft driven gear washer & shim stack ? All are in the same position with the following exceptions: Slot does not exist on the 1111263 racing distrib on the left (for big block reverse rotation cam), and I notice that on '65-6 BB units (ie. the 1111093) that the slot is relocated to the opposite side, so as not to interfere with the fully machined section face on the annulus. Colvin's Chev '65-9 book shows GM drawings with the comment that the slot is optional (1111240 and 1111267). A revision comment on the '240' drawing indicates that on 8-4-67 "oil annulus revised".
y
y
