C1 Fuel Delivery - NCRS Discussion Boards
C1 Fuel Delivery
  • Bob W.
    • August 31, 1981
    • 84
    C1 Fuel Delivery
    The fuel in the tank is varnished and have gotten a replacement tank but should I replace the fuel lines as well. When I took the fuel line off running from the tank to the frame rail, all the fuel was dark dark brown and varnished. Should I replace all the fuel lines as well or is there a way to clean these? Where would be the best place to buy them, Quanta doesn't have them.
  • John F.
    • March 23, 2008
    • 2395
    Re: C1 Fuel Delivery
    I blew denatured alcohol thru mine, then checked the carb in-line filter a few times. No problems. Same steel line on the car for 50+ years.
    • Paul J.
      • September 9, 2008
      • 2091
      Blow the lines out with carb cleaner. Anything missed will disolve with fresh gasoline.
      • Bruce B.
        • May 31, 1996
        • 2930
        Lacquer thinner works well but don't run through fuel pump.
