Is this the real deal? I removed it from a box of stuff I had that came with the car. I am cleaning out the garage and I have to toss some stuffIMG_0886.JPG
Fan clutch 1960
Re: Fan clutch 1960
Don't throw it away.
Can't say for sure it is a 1960 piece, but it should be correct for just about any Corvette through 1967. There were two designs, and this is the Eaton (coil) one. Small blocks and big blocks had slightly different shafts. Can't see this feature to tell which one you have. These Eaton units were also ink stamped on the front to indicate date and whether BB or SB application. Your picture does not show this due to age. The other design was the Schwitzer (bar) design.
If you can provide additional pics that would help. On the Eaton design, the fluid reservoir ends changed from retangular shape to trapazoid shape beginning in 1968.
Larry- Top
Re: Fan clutch 1960
Can you see any faint ink marks on the face of the fan clutch that you already photographed??
Al: Before I receive some comments/corrections from others, the Eaton style first appeared around 1960 or so..........therefore I do not think it is suitable for the earlier cars. My comfort zone is the mid-years. I frequently get corrected when I comment on the C1 cars.- Top
Re: Fan clutch 1960
Larry,
LOLdon't worry about it. I get corrected everyday. My comfort zone is nothing..
IMG_0891.JPGIMG_0892.JPGIMG_0893.JPG- Top
Re: Fan clutch 1960
Al,
Your fan clutch looks like the one I bought last year that was stamped "EATON CJ" and "L27G" (Nov. 27, 1966) and came with 18" 5-blade fan stamped "912239", "SC", and "L6" (November 1966) used on 1966-1967 Corvettes w/AC.
Dave- Top
Re: Fan clutch 1960
Al:
Looks like you are getting some good, additional information. To help decide if this is a BB or SB fan clutch, you need to measure the shaft length from the extreme end of the shaft flange to the boss for the fan blade attaching stud(s). If it is 1.8 inches, it is a SB application. If 1.5 inches, it belongs to the BB.
Hope this helps. There are two or three guys who can restore these fan clutches and properly stamp them, if you want to have this done. Their names are in the DRIVELINE or in the archives. Or let me know if you cannot find this info.
Larry- Top
Re: Fan clutch 1960
Al:
Larry- Top
Re: Fan clutch 1960
This is a picture of the Eaton fan I had restored by Fred Oliva for my 1960 270 horse engine:
Hope this helps!- Top
- Top
Re: Fan clutch 1960
I got the over spray on it when i was painting the blades. Maybe i should sale the blades with it. Not sure what its worth or how much the correct one cost. I looked at CC to find it but no luck. I bought one from autozone that works. I am happy but next year i plan to go for a flight.
This year i just want to drive and enjoy my car before i restore it to flight.- Top
