Fiberglass repair? - NCRS Discussion Boards
Fiberglass repair?
    • April 30, 1984
    • 158
    Re: Fiberglass repair?
    Buy and use disposable gloves.
    • Tom L.
      • October 17, 2006
      • 1439
      Day late and a dollar short. Made some color samples this evening. I see why gloves are important. I will move forward tomorrow and post updates.
      • Tom L.
        • October 17, 2006
        • 1439
        #18
        Made the repair today, didn't take as long and was not as difficult as I thought. Once sanded it looks pretty good. I feel I color matched the patch pretty good, maybee a little dark. my only concern is the color of the surrounding area's after sanding. They are light and the patch and surrounding area's are darker. Any ideas??? Would be nice to make the patch not stand out. Thanks!!
        • Donald H.
          • November 2, 2009
          • 2580
          #19
          If you didn't already, try my suggestion above. I mix some resin then brush it on with a small paint brush. Let it set a couple of minutes, but not completely harden. Wipe it off with a rag. If it doesn't blend, add some acetone to the rag and wip again. You will need to do this to a larger area than just the patch, i.e. for sure all around where you sanded.
          Don Harris
          Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
          • Bill H.
            • August 8, 2011
            • 439
            #20
            [ATTACH=CONFIG]38941[/ATTACH]
            What is the sandpaper grade you last sanded with? I'd go to 600-1000 and wet sand it.
            Then do what Don suggests with the resin.
            • Russ S.
              • April 30, 1982
              • 2161
              #21
              [QUOTE=Lynn Larsen (46337);609243]Made the repair today, didn't take as long and was not as difficult as I thought. Once sanded it looks pretty good. I feel I color matched the patch pretty good, maybee a little dark. my only concern is the color of the surrounding area's after sanding. They are light and the patch and surrounding area's are darker. Any ideas??? Would be nice to make the patch not stand out. Thanks!!
              Lynn, Here are two other things you can try. !. Try buffing the area on a buffing wheel. If that doesn't satisfy take a tiny amount of the dye you used on a rag and rub it into the area. If needed try rebuffing after the rubbed in dye.
              • Tom L.
                • October 17, 2006
                • 1439
                #22
                After seeing what I had after using 22 grit paper I tried wet sanding w/ 400, all I had at the time. All it did was make the surface smooth and shiny. I'll try the dye and resin. I'll see how it goes. Either way it's still a lot better than it was. Thanks!!
