1965 Jack.... Type I vs Type II - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    How does one tell the difference between a type I and type II jack?
    Dave
  • Jaime G.
    • April 1, 1988
    • 480
    Re: 1965 Jack.... Type I vs Type II
    Hi David.
    I think the only difference is a stamping in the lifting arm. Like a reinforcement plate.
    I have seen very few type 2s around.
    Regards
    JG
    • Joe R.
      • July 31, 1976
      • 4547
      The article in "The Restorer" would be the best place for that information. Article was written by somebody in the backwards state of Arkansas. Must have written the article during the day as they have to pump sunlight into that state.
      JR
      • Tom H.
        • December 1, 1993
        • 3440
        Originally posted by Jaime Gesundheit (12617)
        Hi David.
        Regards
        JG
        Type 1 and type 2. They are different. Here's a type 1.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Jim D.
          • 2882
          According the the Judging Guide and Joe's article, the type 1 was used in "early" 65's. I wonder what the definition of "early" is? My April car (#14790) has it's original jack and it's a Type 1. That's almost 2/3's of the way through the model year.
          • Gary S.
            Super Moderator
            • February 1, 1984
            • 456
            I was not sure what a Type II jack looked like, but after studying my jack pictures, TDB past descriptions and what the vendors are selling for repro, I made up these pictures. Am I on track here? No access to Restorer articles to check.
            First, this is a known picture of a Type I Jack. Trunnion nut out and sealed collar washer. Note the lift arms are flat steel stampings
            I believe this is a picture of a Type II jack. It is exactly like a Type I jack only the lift arms have a crimp in them that does not appear in the Type I jack. Are these crimps the "reinforcements" that are said to be the change?TypeIIJackReinforcement.JPG
            Of interest is the repro jack listings for Long Island Corvette Supply and their listed use as shown:
            Type I: Used in 63 to 65 Vin 7,000
            Type II: Used 65 Vin 7,000 to 23,564 (65 Survivor two-owner car has a Type I jack)
            Type III: Used 65 Vin 23,564 thru 66 and 67
            Paragon listing of repro jacks and their listed use:
            Type I: Used in 63 thru 65 Vin 7,000
            Type II: Used in 65 Vin 7,000 to 65 Vin 21,000
            Type III: Used in 65 Vin 21,000 thru 66 and 67.
            Specifically, Paragon has a special picture of their Type II jack showing this reinforced section as seen next:
            All type III jacks appear to continue with the reinforcement in the lift arm. The trunnion nut is inboard and the collar has a nylon washer.
            Any thoughts?
            Gary
            Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
            • Joe R.
              • July 31, 1976
              • 4547
              Here is a list of the 65's that listed the SN in the survey. Not all are represented here but just the ones who pledged on a stack of Bibles that their Corvette was original.
              12,XXX TYPE II
              13,XXX TYPE II
              14,XXX TYPE II
              19,XXX TYPE II
              19,XXX TYPE II
              20,XXX TYPE II
              22,XXX TYPE I
              22,XXX TYPE III
              jr
              • Jim D.
                • 2882
                12,XXX TYPE II
                13,XXX TYPE II
                14,XXX TYPE II
                19,XXX TYPE II
                19,XXX TYPE II
                20,XXX TYPE II
                22,XXX TYPE I
                22,XXX TYPE III
                jr
                You can add my Type 1 to your list. It is the jack the car left the dealership with on 4-23-65. Of course there is the possibility that the car left the factory with a Type 2 jack and the dealer swapped in a Type 1 jack before it was delivered the day after they received it.
                • Gary S.
                  Super Moderator
                  • February 1, 1984
                  • 456
                  I completely rewrote my post above. Should have deleted it and posted a new one, but too late. Check it out and see what you think.
                  • Joe R.
                    • July 31, 1976
                    • 4547
                    The jacks were reproduced by John Smith in Miami, Oklahoma using "The Restorer" article for his research. During the early years we spoke many times and the jacks were reproduced very carefully on tooling purchased by Mr. Smith. John no longer is affilated with the company that produces the jacks.
                    JR
                    • Tom H.
                      • December 1, 1993
                      • 3440
                      Gary, I'm not sure that one shot you have is actually a type 2. The end doesn't appear correct. Am I wrong on this ?
                      http://forums.corvetteforum.com/c1-a...3-c2-jack.html
                      Tom Hendricks
                      • Joe T.
                        • December 1, 2000
                        • 131
                        would it be possible for you to look at a jack on e-bay for me and see if it is a type jack appropriate for my May 63 swc? I would greatly appreciate it, the search term I used is 1963 corvette jack and the sellers username is markawsarat. if you have time I would be greatful, Joe
                        • Gary S.
                          Super Moderator
                          • February 1, 1984
                          • 456
                          Ebay jack appears to be a Type II. You need a Type I. Type I looks just like the one on Ebay except it should have the flat lift arms on the end near the screw head like shown in this picture. My picture in post #7 shows a Type 2 with the reinforced lift arms. Anyone disagree?
                          • Joe T.
                            • December 1, 2000
                            • 131
                            thank you very very much, JOe
                            • William D.
                              • April 1, 1993
                              • 101
                              Vin# 21326 - Type 2. Here's a pic!
                              1965 Conv 327/365HP 4 sp, 3.73, KO's, pb 96.6 pts
                              1965 Coupe fuelie, F40, 411's, teak/tele, 32K, 98 pts
