54 chasis start up observation - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    With the tranny in neutral, the rear wheels still turn. I found that to be odd. The other gears work fine. The tranny is full. Probabley no big deal, just an observation. Got it nice and hot, ran for 45 minutes. on restart the engine cranked as though the battery was low but it wasnt. Kind of a intermittent cranking, it didnt "flow" smoothly but then started smoother cranking once it got going. Maybe timing issue? Hard as hell to see that little ball bearing even after painting it bright orange. Any tricks on timeing to see the bearing? Thanks as always
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 chasis start up observation
    with the wheels off the ground and in N
    the wheels will turn slightly - normal
    they do turn over slow - normal
    compared at a v8
    check your ground connection at the transmission
    I place my ground strap under the transmission dip stick
    there is a photo in Nolans book - the strap is under the dip stick
    It is hard to do
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
