I have an antifreeze leak between the front engine mount crossbrace and the block on my 1961 Corvette. According to my service guide there should be a gasket or gaskets between the crossbrace and the block but I don't find them in my parts books. Do I use 4 water pump gaskets two under the crossbrace and two under the water pump or is there special gasket for the block to crossbrace joint? Thanks for the help.
Antifreeze leak on 61
Re: Antifreeze leak on 61
I used four of the same standard water pump gaskets, one on each side of the crossbrace of course. Seems to be fine.- Top
When you have it apart, check the integrity of the cross race. They often are rust-pitted, and leaking results. Also, it's difficult to get the brace and all four gaskets lined up to go back together--cut the heads off a couple of extra 3/8 bolts , use them as guide pins, and then when you have two regular bolts in and securing it all, remove the guide pins and replace with correct bolts.- Top
Oops! Forgot the picture of the cradle.- Top
