Had a judge at nationals note that the tie rod to drag link sleeve bolts were too long and should be "tr"" designation. The bolts do need to be 1/4 shorter, but these are "ur" designated bolts. Does anyone have correct bolts designation? They should be grade 5 fine thread 5/16 bolts with lock nuts the best i can tell. Not sure if he meant "ur", which paragon shows for this application, or should they be "tr" designation. This will be a simple fix soon as can obtain correct ones.
1959 judging issue
Re: 1959 judging issue
Gary,
I will give you a free ride to the top.
I can not tell you anything much about 1959s -- BUT I can tell you that almost never is there only one head mark applicable to a specific position on a Corvette. As you know the head mark indicated not only the grade of the fastener, but also the supplier. For what seems like a common bolt like this, I would expect several head marks might be appropriate. Hopefully someone with an intimate knowledge of the 1959 chassis will be able to help.
Meantime enjoy the ride.Terry- Top
Gary, currently doing frame on restoration on C-1. Am original owner and some what an accomplished mechanic. Have an original tie rod sleeve bolt in my hand. This bolt is actually 1-1/8 " long with an L mark on head. We have replacements from Zip and they are 1-1/4" long with UR head mark. Corvette Central indicates a TR head mark, but just checked their web pic, it is UR head mark. Ahhh, the repro market is great. Obviously, I'm using whats available.- Top
Gary,
Richard Brodeur who posts here IIRC did an inventory of '59 bolt head markings.
As Terry said most applications might have used more than 1 bolt manufacturer (head marking).
Most of the original tie rod adjustment bolts I've seen had L head markings.
The vendors seem to follow the "general rule" that suspension bolts head marks were typically TR with some UR thrown in.
The 56-7 Judging Manual 5th edition revision team spent a lot of time trying to compile the different bolt head marks and where used.
JMTCW,
Gary
....NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
