Re: Rag joint bolt on 68
Gary-----
The AMK bolt is available in two different finishes. Under the part number I mentioned, the bolt finish is coded "S2". This decodes to "phosphate and oil (gray-black)"
Under a different number, the same bolt has a finish coded "S60". "S60" decodes to "phosphate and red pigment". I don't think a bolt with the red pigment was used on Corvettes.
Gary-----
