When I removed the mounts there was an assortment of bolts in both the block and onto the frame. Does anyone know what are the correct lengths of each and what the appropriate head markings are??? I have a bunch of stray bolts and was hoping some might match. Thanks!!
Motor mount bolts
Re: Motor mount bolts
Lynn-----When I removed the mounts there was an assortment of bolts in both the block and onto the frame. Does anyone know what are the correct lengths of each and what the appropriate head markings are??? I have a bunch of stray bolts and was hoping some might match. Thanks!!
The motor mount-to-block bolts were 3/8-16 X 15/16", black phosphate, and trimmed (i.e. non-"indented") head. I don't recall headmarkings. I'm sure there were at least several.
The through bolt is 7/16-14 X 4-7/16". It is zinc plated or electro-galvanized and has a trimmed head. It also has a pilot tip.In Appreciation of John Hinckley- Top
Hi,
The original mount to engine bolts on my mid-January 71 are a bit different than you descrbed Joe.
They're indented head with a captive split lock washer.
Did the style of bolt vary over the years?
Chapter Top Flight October 2011- Top
I agree Alan - my 71 and 72 are exactly as you have pictured including same headmark.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Joseph------
I'm not sure of the finish on the 1967 bolt. It was shorter than the 70+ bolt due to the fact that the pre-1970 engine mounts were of the non-locking variety. I'm not sure about the nut but I think it was a zinc-plated, lock nut.
ADDENDUM: From what I can determine from specs, the nut used for the through bolt was a 7/16-20 slotted locking nut, zinc plated, and 11/16" across-the-flats (wrench size). A slotted locking nut is a rather unusual configuration on GM cars. This nut was used through 1969 but not thereafter.In Appreciation of John Hinckley- Top
Alan-----
I was incorrect on my description of the bolts. My recollection was that they had a trimmed head but on further checking I find the GM #3748038 did have an untrimmed ("indented") head. They also did have the captured lockwasher. Of course, the captured lockwasher is a PRODUCTION-related convenience. For a restoration it's not necessary to use a bolt with a captured lockwasher. No one will ever know that the bolt and lockwasher are not an assembly.In Appreciation of John Hinckley- Top
Hi Joe,
Thanks for the reply.
I was curious because I DO value your knowledge on parts, fasteners, and finishes!!!!
Alan71 Coupe, 350/270, 4 speed
Joe -
As I recall, those were Marsden nuts, and that was the only Corvette application for that unique style of locking nut; they were also found on many 1st-generation Camaro and Chevy II rear leaf spring rear shackle plate bolts.
MarsdenNut3.jpg- Top
Mine are the "deformed thread" nuts that are sort of shaped like a triangle internally.Joe -
[ATTACH=CONFIG]38974[/ATTACH]
I'm sure there is a proper name for them.
The same style is used to hold the power brake booster to the firewall on the inside. Worst nuts to remove on the whole car.
Patrick-----Mine are the "deformed thread" nuts that are sort of shaped like a triangle internally.
Patrick
They are called stover type lock nuts. 1970+ Corvettes used this style lock-nut on the through bolts. These are 7/16-14 whereas earlier used 7/16-20 slotted locking nuts.In Appreciation of John Hinckley- Top
Joseph------
I'm pretty sure the GM #3817224 bolt used for most 63-69 was zinc plated, just like the longer 70-82 bolts. However, I'm not 100% sure as the 3817224 was never available in SERVICE.
By the way, 1965 with L-78 used a different bolt----GM #3832465. Why? Well, it probably had something to do with the fact that application was also supposed to have used unique, side-specific motor mounts. How were the mounts and bolt different? I do not know and neither the mounts nor the bolt were ever available in SERVICE. Were these parts actually used in PRODUCTION? I do not know that, either.In Appreciation of John Hinckley- Top
