I found a 1957 dual quad engine for sale, but it has a F425EB stamp on the pad. What is that from? Thanks for any tips.
1957 engine
Tags: None
Re: 1957 engine
OK, thanks, very interesting, not even a '57! Kind of misrepresented.Big Tanks In the High Mountains of New Mexico- Top
Re: 1957 engine
Found some more
EB 55 265 Truck 15 422 1 Manual2-Brl
EB 57 283 Impala 270 469C 3-spd 2 4-Brl Carter WCFB, HP solid cam
EB 58 283 Impala 230 410 Power glide4-Brl
EB 59 283 Impala 230 410 Power glide 4-Brl
EB 60 283 Impala 230 410 Power glide 4-Brl
EB 61 283 Impala 230 410 Power glide 4-Brl
EB 65 327 Chevelle 300 L-74 Manual 4-Brl Hyd Cam, AFB
EB 66 327 Chevelle 275 L-30 Manual 4-Brl Hyd Cam, AFB, A.I.R.- Top
Re: 1957 engine
it is not necessary to list all the different years that EB is used. F425EB will only be found on a 57 block pad. the other years have different arrangement of pad numbers.Found some more
Re: 1957 engine
No such animal.EB 57 283 Impala 270 469C 3-spd 2 4-Brl Carter WCFB, HP solid cam
Top of the line in '57 was the Bel Air.
Also, '57 passenger car engine codes weren't specific to the trim lines. An EB engine could have gone into a 150, 210, or a Bel Air.- Top
Re: 1957 engine
in 1957 , what was the transmission used with the EB motor?- Top
Re: 1957 engine
pre 57 cars had 7 digit engine sequence numbers on the pad and mid sixty EB pads were showing partial vin#. i did not include any late 50 or early 60 EB engines because none had the dual quads that mike mentioned.- Top
