1965 corvette water pump pulley - NCRS Discussion Boards
  • John S.
    • January 1, 1998
    • 81
    What are the dimensions for the correct water pump pulley for a 327 365 hp hi-performance 1965 corvette? What are the widths of the deep grooves? What is the OD? This is a L76 with no air.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1965 corvette water pump pulley
    Here's the one you're describing; The P&A catalog says 7_1/8" OD. I'll get the other dimensions in a few hours, as it's uninstalled, in my basement.
    • John M.
      • January 1, 1998
      • 813
      Wayne, Did the SHP pulleys have that backup washer shown in the picture? It's been so long since I put mine on I can't remember if it was there.
      Tx
      John McRae
      • Wayne M.
        • March 1, 1980
        • 6414
        No John, I don't believe the reinforcement #3720616 was ever TFP for '65 or prior C2. Maybe used in '66 or '67+ due to high belt loads on the water pump with certain options. I know there's bulletins out on this.
        Here's the other two shots of the '245'. As the forward groove is added by pressing on to the rear groove / cone, there is only one groove looking at the inside.
        • John M.
          • January 1, 1998
          • 813
          Thanks Wayne,
          John
