1973 vaccum hose grommet source - NCRS Discussion Boards
  • Roger C.
    • March 1, 1998
    • 83
    Hello all
    according to the 1973 aim the firewall hole diameter for the 3 hole vaccum hose grommet is 1-5/8"
    I purchased what I thought was going to be the correct diameter from three different vendors
    They all are for an 1-1/4 in diameter. Those grommets just fall through the hole.
    Is there a souce for the larger grommet, and where would the smaller diameter grommet be used?
    Just curious who else has run across this.
    Roger
    • 3415
    Re: 1973 vaccum hose grommet source
    Hi Roger,
    Is this the grommet you're asking about?
    The over-all diameter is 1 1/2" inches.
    I have an extra you may have. I'm not sure here it came from. Maybe Smart Parts at Carlisle.
    • Roger C.
      • March 1, 1998
      • 83
      Alan,
      It is going to require something around 1 7/8"
      the one you picture and describe as 1 1/2" is the diameter is the same of the three I purchased from other vendors
      Thank you for your offer
      I have learned not to throw any thing away on these cars until you know for sure the replacement is going to work
      I will look in my bone pile and hope to find the old one
      Roger
        Originally posted by Roger Clark (30253)
        Alan,
        Roger
        Roger------
        Is yours a THREE HOLE grommet? I thought that 1973 and later used a TWO hole grommet. In any event, if it is a three hole grommet then 1973 must have changed from earlier. The earlier grommet, GM #3934269, is 1-1/2" OD as measured at the forward edge of the grommet.
        • Roger C.
          • March 1, 1998
          • 83
          Joe,
          This has been a ten year basket case body off restoration.
          I do not know what was original, but I will check on the two hole angle.
          Thank you
          Roger
          • Roger C.
            • March 1, 1998
            • 83
            Joe,
            Mystery solved
            It is a two hole grommet
            I found it in a box I set back
            Thank you for the clue
            Roger
              Joe,
              Mystery solved
              Roger
              Roger------
              I believe this grommet was supplied to PRODUCTION as part of the vacuum harness assembly. Also, I cannot find where it was ever available in SERVICE separately. So, I have no GM part number for it. I do not know if it's reproduced.
