1960 trunk marking ID - NCRS Discussion Boards
  • Timothy A.
    • January 2, 2007
    • 24
    Hello,
    I am going to restore my truck area from a back yard restoration job. I was taking off the paint (which ws not the original) and I un-covered a strong beutiful green factory mark which I assume was the body paint mark. Can someone I.D this code. I think the W stands for White but the other letters I cannot make out. Would that be the cove color?
    Tim Allen
  • Edward L.
    • 278
    Re: 1960 trunk marking ID
    Originally posted by Timothy Allen (46673)
    [ATTACH=CONFIG]39151[/ATTACH][ATTACH=CONFIG]39152[/ATTACH]
    Hello,
    Tim Allen
    The paint code is "Ivory" which was used to designate the exterior color. Cove colors were not indicated. The only other marking you will find is "HT" if the car was equipped with a hard top.
    Ed
    • Edward L.
      • 278
      "Ivory" was used to designate white.
      • Timothy A.
        • January 2, 2007
        • 24
        Duh.......All my eyes could see was a W. Thanks Ed, the word Ivory is clear as day now. I couldn't see the woods for the trees.
        Tim
        • Timothy A.
          • January 2, 2007
          • 24
          Ed, How was the cove color designated? My car has mounting for a hardtop. Where would that marking be.
          Thanks again,
          Tim
          • Joe M.
            • April 30, 1990
            • 1338
            ivory = Ermine White
            • Edward L.
              • 278
              Thanks again,
              Tim
              Tim:
              If the car came with a hardtop from the factory, the hardtop designation (H/T) would be in the same area you found the "Ivory" marking. My guess is that the H/T crayon mark was there only to indicate that the deck lid would need to be drilled to accept hardtop hardware.
              The cove color, if there was to be one, must have been part of the job order. It was not indicated on the car body.
              Ed
              • Timothy A.
                • January 2, 2007
                • 24
                Thanks Joe.
                TIm
                  Ed
                  Ed -
                  That's correct - if a given body required a side cove two-tone, it was noted on the daily schedule sheet given to the Paint Shop Superintendent, and was not marked anywhere on the body.
                  • Timothy A.
                    • January 2, 2007
                    • 24
                    Thank you guys for all of your help.
                    Tim
