Cost range of wheel for 63 - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    I discovered that my wheels are of mixed specs and would like to have them all the same. I would prefer the convenience of ordering them as opposed to looking for them in a swap meet. What should I expect to pay for 15 X 6 (nominal 0.50 offset) plain steel wheels (I have radial tires).
    Steve
  • Harry S.
    • July 31, 2002
    • 5258
    Re: Cost range of wheel for 63
    Steve, the 15x6 wheels will be signifanctly less expensive than original 15x5 1/2 63 wheels. Here is a set on ebay:
    The problem is with any used wheel you have to be concerned about dents and run-out. If your not going to have them judged look at Ecklers for a new set, but they are 15x5. You can also try Paragon, or the other parts folks. For driving I went with a set of repro bolton knockoffs.
    • Rick A.
      • July 31, 2002
      • 2147
      personally, if you are looking for "replacement" wheels I would be talking with Virginia Vettes
      Rick Aleshire
      2016 Ebony C7R Z06 "ROSA"
      • Michael G.
        • November 12, 2008
        • 2155
        It doesn't sound like you want to hunt for original 63 steel wheels. That's good, 'cause you would have to just empty your wallet on the table ( 5 nice ones may cost you $2000 or more)
        63's had 5 1/2" wheels, (not 6") and you can can buy not-correct repops new for about $120 each from several vendors. If you want to go to 6 inch wide, 67 rally wheels should be about the same price.
        • Steve D.
          • February 1, 2002
          • 990
          Harry,
          Thanks. I found some at what seemed like a reasonable price, but wanted to check for board wisdom on the subject.
          Steve
