Five-Leaf HD Leaf Spring Clamps - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    I have a pair of the 5-leaf HD leaf springs that I want to restore. They have the steel clamps on them to hold the bands. I'm sure I can get them off, but I doubt if they'd be reusable? Are these clamps reproduced? Does anyone have any tips on getting the old clamps off and back on?
    Bob
  • Joe M.
    • April 30, 1990
    • 1338
    Re: Five-Leaf HD Leaf Spring Clamps
    Are they different than the clamps used on the non HD leaf springs?
    • Mike E.
      • February 28, 1975
      • 5134
      Very. Very. (had to put it twice--too sort for the website)
      • Joe M.
        • April 30, 1990
        • 1338
        Would it be possible to heat the bent-over pieces with a torch and then use a thin pry bar to open the folded sides? Is there room to insert a thin pry bar? A good machine shop could probably make it happen.
        • Paul M.
          • November 1, 1987
          • 142
          Bob, You need to heat them with a torch and then bend them open. You would do the same to reclose them. A press also helps to get them closed up. I would not take the rivet out.
