Good Year Run Flats
Re: Good Year Run Flats
I spoke with the Corvette mechanic at the local dealership today. I do not know if this is true but this is what he said.
All new Corvettes are setup and wheels aligned for racing. Meaning, lots of cornering. The result is excessive tire wear. He said to have the car aligned for normal street driving and this will significantly extent tire life.
Can anyone comment on this?Terry- Top
Based on a previous thread, I took my new 09 C6 to the dealer to have it aligned.
If I remember correctly, the alignment tech showed me the GM computer screen. It had specs for "touring". I had my alignment changed to that.
Thanks for the advise guys.
Bill
- Top
2007 Z06, I stretched the first set of tires out to 15K miles. Rears weren't as bad as the fronts but all 4 were done! Fronts had the wire brush look on the first 3" of inside tread!!! Next 2 sets of tires didn't last any longer either. I will switch to Nittos for next set and see if they are any better.
Thanks to everyone who gave me the excuse that it is the alignment and not my driving habits!!- Top
Harry...do you know what the specs were for your alignment? Here are the recommended factory specs for the different suspensions. Do you know if they used any of these?Attached Files- Top
Here is where we started:
Front Camber -0.8 -0.8
Caster 7.6 7.0
Toe -0.01 -0.03
Here is where we ended:
Camber -0.2 -0.1
Caster 7.8 8.0
toe 0.05 0.04
Rear Start
Camber -0.5 -0.6
Toe -0.15 0.01
Total toe -0.14 -0.08
Rear ended
camber -0.5 -0.6
toe 0.00 -0.01
Total toe -0.01 0.00
- Top
Can anyone comment on this?Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
Thanks Harry and Vinnie. New tires on car (Nitto Invo's) Doing alignment early next week. Great to have these specs. Vinnie, you mentioned carrying a "fix a flat" type product. How would that effect the tire pressure sensor if used? Any idea. Let me know.
Thanks.- Top
Thanks.- Top
Deane...the Slime yellow label sealants are supposed to work just fine with tpms sensors...but I'm not an expert and have no experience with using it yet...website also says it can be washed out with water after the tire is broken down to repair the tire from the inside...
From the Slime website
Does your vehicle have a TPMS (Tire Pressure Monitoring System)? Use our yellow label sealants with the TPMS Safe icon. They are specially designed for use in tires with these systems.- Top
