L88 Cam - NCRS Discussion Boards
L88 Cam
  • Michael H.
    • January 29, 2008
    • 7477
    L88 Cam
    Did early production 68 L88 Cars use the 1st design L88 cam that was used for 67 before the 3925535 cam was available? Possibly the 1st month of 68 production??
  • Dick W.
    • 10483
    Re: L88 Cam
    With the large spread between assembly date and installation in the cars I would tend to believe so, maybe even later.
    Dick Whittington
    • Ray K.
      • July 31, 1985
      • 369
      Re: L88 Cam
      I also tend to think that the earlier #3879605 camshaft would have been used for the early production of the 1968
      L88's.
        Re: L88 Cam
        Michael------
        According to GM, yes. In fact, I think that most 1968 L-88 may have used the earlier cam.
        • Michael H.
          • January 29, 2008
          • 7477
          Re: L88 Cam
          Thanks guys. I think we agree. I don't think the 1st design cam was used for very long in 68 engines but I do think it was used for at least the first month or two.
          Unfortunately, without some documentation, we may never know for sure.
          Does anyone happen to have a known original cam from an early 68?
          The 3879605 67 L88 cam was available from Crane cams years ago but I doubt if anyone sells it today. I supplied the correct cam for the Burroughs/Krughoff 12 mile 67 L88 decades ago. It came from Crane Cams.
          • Dick W.
            • 10483
            Re: L88 Cam
            I don't have my books with me, but see if this cam is close Michael
            CS-165R BASE MODEL; Performance Cam; Pro-4000 Perf. Cam; Mechanical, (050) Duration at .050 Lobe Lift, 242 Exh., 242 Int., 114 Degrees Lobe Separation, 0.52" Exh. Valve Lift, 0.52" Int. Valve Lift
            Dick Whittington
            • Michael H.
              • January 29, 2008
              • 7477
              Re: L88 Cam
              Thanks Dick. I'll check it out. I have the original Specs for the 3879605 here.
              • Clem Z.
                • January 1, 2006
                • 9427
                Re: L88 Cam
                the 605 had a grooved rear cam journal so i would doubt the GM would use them in 68 blocks. all L-88 68 and up short blocks and complete engines i ever tore apart to blueprint had a 535 cam
                  Re: L88 Cam
                  clem------
                  1967 blocks had the same rear cam journal machining as 1968 blocks.
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    Re: L88 Cam
                    clem------
                    i never had a 67 L-88 engine to work on and the cam in a 67 would not need the groove. i used the 605 in 66 short track 427 race engines as there were very few after market cams for BBC in 66.
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      Re: L88 Cam
                      Clem,
                      Pretty sure the original 3879605 cam from the Burroughs/Krughoff 67 L88 car had a grooved rear journal like a 65-66 cam even though it had a 67 style rear cam bearing.
                      You can use a cam with a grooved rear journal in a 67 and later block.
                      I think a lot of the over the counter 3925535 68-69 L88 cams also had the grooved rear journal.
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Re: L88 Cam
                        Dick,
                        I dug out the GM cam sheets for the 3879605 and 3925535 L88 cams but the checking clearance is @ .020" instead of the .050" on your chart so the numbers are not going to mean much.
                        I'll try to scan and post later.
                        • Richard L.
                          • December 1, 1994
                          • 43
                          Re: L88 Cam
                          I have a late 67 early 68 L88 new over the counter CE short block #321. It has a 3904367 cam in it, stamped 4367. Cam has no rear groove. Clem verified this as an L88 cam a while back.
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Re: L88 Cam
                            I still can't find any numbers for lobe lift @ .050" but here's what I did have. Both the 67 (3879605) and 68-69 (3925535) cam specs are shown at .020".
                            The 67 was actually a bit nastier than the 68-69. Slightly higher lift and a bit more duration.
